jgvabronco
- Joined
- Dec 15, 2005
- Messages
- 10
- Reaction score
- 1
The wedges I bought from JBG are 5/8" too long when I put them on the 3-1/8" axle tube. Anybody else experience this? What did you do about it?
So I supposed you used the rear bolt in the arm for the lower spring retainer, and then drilled and tapped the other bolt hole in the spacer? This didn't throw the left front shock off, or did you switch to just 2 rear shocks?I just made spacers that go between the radius arm and the caps
31284[/snapback]
