Have a 69 Bronco with a 302, and just installed the Vintage Air A/C setup. The motor is running hot and I want to increase the air flow, or cooling capacity, but have limitations because of clearance problems with the fan blades hitting the A/C compressor. Has anyone ran this setup, and what was their solution??
25256[/snapback]
The older 302's have been notorious for overheating problems, so I'm sure you'll get several responses to your question.
Here are some options I've heard/seen/read:
1. Sealing the gap between the top of your current radiator and the hood. Some guy over at www.classicbroncos.com had a pretty nifty solution. You may want to go over there and do a search on it... sorry... I don't know the link off hand.
2. Upgrading your radiator. I'm assuming you have a 3-core in there now. You may consider running a 4-core or aluminum.
3. Fan shroud. Do you have one? If not, I would definitely get one.
4. Vented fenders. Supposedly they help increase airflow through the engine compartment.... sounds good in theory, but I have never tested this nor do I know anyone personally that has done this.
I'm sure there are many more options, but that's all I can think of. Good luck to you!
