Cherry Bomb turbo muffler
walnuts75
Ohio
I bought a cherrybomb turbo muffler the other day and now I don't know which way it goes in. Does the offset side connect to the catalitic converter or does the centered side connect to the cat? Or does is matter? Does anyone else have this muffler? I was also wondering how it sounds.
shift1313
VA
probably wont matter. if it does they usually have IN stamped on it and OUT.
im using a summit center in offset out muffler reversed so i can tuck it up into the frame rails.
Shadow_D
Schenectady, NY
Exactly, it would be stamped with in on one end and out on the other...
What is the part number? On Jegs website it shows the following for Cherry Bomb Turbo Mufflers.....
Center In / Dual Out
Offset In / Offset Out
Offset In / Center Out
"In" would be the motor side (front of truck) and "out" would be the tip side (Back of truck)
Redneck86
First On Race Day
Colorado
Turbo mufflers are reversable, Thats what the Cherry Bombs website even says that they are. I think it just chambered mufflers that have be put in a certain way. From what i know Cherry Bomb Turbos and Glasspacks are reversable
walnuts75
walnuts75
Ohio
The muffler has an arrow pointing in both sides and the centered end is stamped with a "B" while the offset end is stamped with an "A". What does this mean? Sorry for getting back to this post so late. But like redneck86 said, I think it might be reversable.
kyleh01
