centech wiring
jimmycrown
nw ind
getting ready to install a centech harness in my buddys 66.has anyone used ths and is there any thing i should watch out for?we also installed a flaming river column there are two white wire that come out of it anyone know where they would plug in ?
S_bolt19
Colorado
Centech harness is pretty easy. The only problem I had was with the wiper motor wiring. #1 it is hard to fish it up through the windshield frame and #2 read the directions a couple of times because this part is a pain because if I remember right, there is a wire on the motor itsself that you have to clip to get it to stop. Otherwise, when you turn it on, it will continue to run even if the switch is off. If you bought the harness through Centech, they will give you tech support, if you bought it through a vendor, then they pretty much leave you out to dry. That is what happened to me when I had that problem.
But you should definitly read the directions a couple of times first.
73dreambronco
just put my centech in, piece of cake, great directions  take your time and just follow the  steps. good luck
32749[/snapback]
Sandoval_broncosauria
