Nope ya need too check the front springs first and then check you C bushings on the axle,for wear and breakage, no matter what you read the C bushings are easy too set up on flat ground, never had too do mine more then twice, if you have a lift make sure your front axle is centered first that always helped me the second and third and fourth time changing lifts( big lifts are not always good)....my bronco leans to the driver side a couple of inches, is there a easy way to adjust this without messing with the suspension?
