Bronco II 1988 Electrical Issues
Andy04180
Accessories stay powered with ignition turned off. I replaced the tumbler and still with it off they stay on. Any suggestions???
I'm not sure with a BII, but if the arrangement is the same, but look on your steering column under the dash. that is where the actual switch on a FSB is located. Perhaps you have the same arrangement. If so, you may need to replace that switch or it could just be out of adjustment.
kyleh01
