Bronco burnout
freak
Indiana
Just messing around.I ran out of driveway.Here's the video.
http://www.supermotors.org/vehicles/regist...a.php?id=204047
Here's the result.
yusuebronko2_86
San Antonio TX
NICE!
maybe you should try to hold the brake a little longer so it works up a lot more smoke and puts on an even more ****-raising show! B) :)>- >:)
F
freak
Indiana
I was just screwing around,I've already done too many brake torque's.I don't have much tred left on my Swamper's.
gregor
gregor
pope afb north carolina
What size engine do you have and what upgrades do you have? I want to see how much I can get out of mine and trying to get some ideas on what to do. :)>-
F
freak
Indiana
400/engine balanced,blueprinted/10 to1 compression/Crower hydraulic cam,degreed in/rod's were reconditioned and shot peened plus the beam's were smothed and arp bolts were installed,small end's bushed/Head's were gasket matched on intake and exhaust side's,exhaust side's were polished,competition valve job,bowl's blended,combustion chamber's reworked and smoothed/SS Ferrea valves/K-Motion valve spring's/Roller rocker's,Crane cam's teflon valve stem seal's installed/KB clevland full floating piston's,Child's& Albert plasma coated file fit ring's/Melling high volume oil pump/MSD billet distributor/MSD 6AL box and coil/Hedman headers with HPC caoting/3"mandrel bent exhaust with Flowmaster super 40's,all ceramic coated/Fluidampr/750 Edelbrock/Aeromotive electric pump/Fuel system is all Aeroquip/Edelbrock dual plane manifold extensively ported.
Drivetrain: C6 race built tranny/2400stall/Hi energy1-2 band/Bushing kit/****** washer's/5 clutch direct drum with torrington bearing's/High performance clutch's/Trans King low gear set with 6 pin steel front plantaries and 4 pin rear plantary/ 2.72 1st,1.54 2nd/Trans King reverse pattern manual valvebody with billet servo/2 enternal perma cool tranny coolers/Ford 9" with Strange supercase and Daytona pinion support/Strange chromemoly 1350 yoke/Detroit locker/mosier shaft's/High angle Driveline's driveshaft with 1350 CV joint/4.56 gear's/Dana 44 in front with a Trac lok limited slip and 4.56 gear's/L&L ladder bar's.
79shortbus
Yeah I did that with a new set of SSR's. I separated the belts on em too. I didnt notice anything until the next day. I went out to the shop and I had huge knots on both back tires. Some how I got em replaced b/c of a factory defect. lol You ever try and doughnuts, that gets crazy when ya try to stop it. I did one a while back and tried to walk it sideways out. worked fine for about 50 ft then it hooked and bout threw me and my passengers out it didnt get outta control just went from sideways to straight really quick. A guy in a mustang did it first then said I couldnt, so I showed em how it was done. We got video of both, mine got everyone up and hollerin, I think it looked better too.
figjeti
