brake problems
cmunson19
I just bought a 78 bronco that has been sitting for a while. I bled the brakes right away. But the pedal won't come back up. I can press it down and the brakes work, but I have to pull the pedal up with my toe to get them to release. :huh:
captmeatmusket
It is your brake booster. I had the same problem with my 78 ranger xlt. If you ca afford it get the booster and master cyliner.
fast_stang_88
Houston,TX
I second that!! Had the same problem as well. You can always just keep puling it up with your foot but the booster and the master would be the correct fix. Good luck now the fun can start!
Sandoval_broncosauria
