Brake Line Remover Help Needed!!!
19BigEddie89
Lafayette, LA
Okay so i have a 6" lift i just installed and required longer brake lines. I removed the brake lines from the the calipers on the front but can't figure out how to detach the brake lines at where they go through the frame(shock mount). And can't seem to figure out how to undo the back. If anyone has any advice or can instruct me on how to do disconnect them would be greatly appreciated. Thanks to all!
19BigEddie89
Lafayette, LA
thank you! so all i have to do is get the c-clip like thing off the side where the tire is and get that off on the back?
Elmo
Forsyth Georgia
the steel line connects to the end of the flexable brake line with a threaded fitting. better to take it loose before removing that clip. And use a line wrench so as to avoid rounding the fitting, that makes it more dificult to get them apart.
eholt80
