"I don't have a suspension lift. Original everything."
Kevin..,
Check the "rubber" on the radius arm ends. (right under your feet) If they're black they're prob. the orig. rubber.
If they, & the "C" bushings on the other end are old & cracked...then while replacing...might as well do the lift thing.
I might be better off going with a 3" lift. I just don't want it to look to hi
It's not all that cheap (lift) ......a good "Bronco" lift is $800-1000 with the good 11pk rear springs. But.., it will ride just like stock. The steering geometery usually needs alteration as well.
Not really hard to do ...about a 3 banana job.. Safety is paramount.
Not enough lift makes big tires look like a "rollerskate"
Not sure 'bout those "senior" steps on the rockers either..?
