BC power Brake install??
NJB71
Hi, well I had some real problems logging back as sibis123(company email i used blocked me -so hence I set up a diff acct)...well since my last discussion, i have swapped out my stock manifold for an edelbrock performer and replaced my stock carb with a 600cfm holley(since no description yet, i run a 302, flame thrower coil, petronix ignition, and said air/fuel mod).btw, did this myself...bragging a little cause prior to that I basically changed oil...So I bought a BC B power brake kit, and want to do install myself. Yes, i hae never done a brake job before. BC supplies instructions, any advice or possible problems I might encounter???
S_bolt19
Colorado
I have never done BC's power brake kit, but I will tell you that it should be pretty dern simple. I did my own junkyard hydroboost brake kit w/out instructions & mine came out great, and BC usually puts pretty good instructions in their kits. I mention that I did my own because I had to make things fit with a brake system. BCs kit is made for EBs. If you run into ANY trouble, call and talk to Chuck, the owner, and he will literally walk you through it. I will say that of all the companies out there, Chuck is the only owner that I have ever had several conversations with. Not to mention, he will make sure that you are up and running correctly.
N
NJB71
TY -good to know...soon as I get the package I'm going to take a crack at it
