Another New Guy
big b
Waxahachie,TX
hello bronco world! I just bought my first bronco about 2 weeks ago. As I was driving it home I noticed that the steering wasn't responding quite the way I expected it to. I talked to a couple of guys about it and they said that it probably was my steering gearbox. So without taking the truck apart what is ths easiest way to check the steering box? :wacko:
fbrown3
West Virginia
Read the miss matched suspension lift article above your post, should give all the info you need.
custom_78
San Diego, CA
Welcome to the B-zone. I had to replace my steering box because it was rear stiff. I first had to replace the steering pump then the lines then I knew it was the box.
Welcome, Big B, to BZ!!! Check for any slack or play in the steering linkage and steering shaft. There is an adjustment ***** on the gearbox, too. Tighten it only in 1/4 turn increments, though!
fred tyler
