Aftermarket A/C
slate
One of my Broncs has an underdash aftermarket A/C, mfg. by Clardy Mfg. here in my hometown of Fort Worth, Tx. Worked when I bought the the truck but the compressor switch was sometimes finicky - took the old one out and cleaned the contacts, stretched the contact spring a bit and it worked for a short time, then didn't. I found a NOS switch and thought my problems were over, but after installation the compressor still doesn't come on. I have looked online for a manual but it seems that Clardy is banckrupt and I am hesitant without a manual to run a 12v lead from my battery and begin touching contacts for fear of shorting out the entire system.
I have checked the connectors with the ignition on and haven't found 12v yet?
It is a three pole resistor type switch with one black, one white and another black terminal lead that is double insulated. Got nailed by 480v when I was a kid and vowed never to mess with electricity again. That vow has cost me through the years! Any suggestions? Is there a rule of thumb that White is always the hot leg?
waternut
Slate,
Check out Vintage Air .com
One of my Broncs has an underdash aftermarket A/C, mfg. by Clardy Mfg. here  in my hometown of Fort Worth, Tx. Worked when I bought the the truck but the compressor switch was sometimes finicky - took the old one out and cleaned the contacts, stretched the contact spring a bit and it worked for a short time, then didn't. I found a NOS switch and thought my problems were over, but after installation the compressor still doesn't come on.  I have looked online for a manual but it seems that Clardy is banckrupt and I am hesitant without a manual to run a 12v lead from my battery and begin touching contacts for fear of shorting out the entire system.I have checked the connectors with the ignition on and haven't found 12v yet?
25026[/snapback]
Sandoval_broncosauria
