demon
I have a 79 bronco, the door tag says 16 for the axle, which i determined was a 3.73 open dif (please correct if wrong). First, how much is it usually for a rebuild at a shop. It is leaking horribly from the seals, and the bearings are shot. Also the pinion out of the 3rd member has major play in it. Should i pick up an axle off of craigslist? And if yes, what years would they swap in from without modification (i don't have ability to weld it right now, and i would swap ring and pinion gear).
