95 bronco rear window button
12cmartin
Have a 95 bronco, the rear window works only if you go to the back and put a key in and twist and then it will go up. On the dash in the front, the rear window button does not work. What should I do in order to get it working again
Welcome to the Zone !!
There are 2 fuses, one for the front button and one for the rear tailgate switch, fuse 14 and fuse 12 in the fuse panel.  Attached is a diagram of the circuit.
Probably the fuse or the button itself, if the door windows work it is most likely the button that needs to be replaced.
therooster
Fort Riley KS
im having the same issue i think? I checked the fuse in the 12 spot and i have power there but not at the switch?
Fuse 14 is needed for the front switch to operate the window.  Check the diagram above.
CamarrX2
