Hello, I have a 1995 f250 that had a 351 in it, the truck had no engine in it when I bought it. I bought a 1994 351w from a local junkyard that was suppose to be a good motor, well I rebuilt it and have it in the truck and it runs fine with a couple of I'm sure minor problems. First of all a 1994 bronco oil filter doesn't not fit it but a 1993 filter does, so I'm guessing that it is a 1993 instead of a 1994 351w. I hooked up all the vacuum lines and ended up with the solenoid on the intake and the exhaust vacuum line unhooked to make it idle. I didn't have any diagram to go by so I'm playing it by ear. It has great throttle response until you put it in gear, then it falls all over itself. Once the rpm's get up it runs much better, but getting it there is rather difficult. Any help would be greatly appreciated. Thanks Mike
