9" rear
73dreambronco
what do I have to take apart to change the main gasket on the pumpkin(on the 9" rear)
do the axels need to be taken out?
TX_BEAST
waxahachie texas
yes pull the axles and then just pull the pumkin out. axles should just have the 4 bolt retaining plate.
justin
Broncoholics
Broncoholics
Washington State
You don't need seals, just go get some form-a-gasket. Yank the axles, you don't have to pull apart the brakes, just undo the 4 axle ****** bolts behind the drum and oull it out. Might be a good time to replace the wheel bearings.
