broncobenny
Broncobenny
If you tried to roll a rear end and the wheels had to turn the same direction together and you were unable to roll one forward and one backwards, what would your first thought be??
If I am reading you right, you have the rear end up on jacks and you spin one tire and both spin the same way. Correct? If this is the case, then you have a limited slip, locked or positraction rear end. An open differential will have the tires spinning in opposite direction when you do this.
Broncobenny,If you tried to roll a rear end and the wheels had to turn the same direction together and you were unable to roll one forward and one backwards, what would your first thought be??
