8in lift??
Hop's Bronco
Holden ,LA
I see alot of people going with the 4in and 6in lifts.... I am wanting to go with a 8in from skyjacker and seeing if anyone had any info on it to help me out in my purchase.... Also i have seen the extended radius arms for a 6in but i have not seen any for a 8in do they even make them and where could i get them???
please help with this major purchase.... thanks
You're right in that Skyjacker is the only company offering an 8" kit for the 80-96 Bronco, while others max out at 6" and Rancho at 4" lift. I know of only one feller that had the 8" on his Bronco, might find an old thread in the forums. IN my experience, while the SkyJ Class II 6" kit is top notch (had it for 3 years), if you're wanting more than that you should seriously consider doing the SAS (Straight Axle Swap) with a Dana 60 front axle. While you may be able to run 38-40" tires with the 8" lift, the stock TTB axle is not made to handle that large a tire. JSM84
muddinlate86
va.beach
i have an 8 inch lift on my 86 i have 6 inch suspension and two inc body.that is as big as i would go with out doing an axel swop.
