89 Bronco 86 F-250 Drivetrain
timberwolf1976
I am taking the driveline out of an 86 F-250 460 C-6 Dana 60 rear, dana 50.5 front axle. How similar are the Dana 44 IFS fronts to the 50.5 fronts? Can I take the guts out of the 50.5 and just change A-arms and knuckles? I want to retain the coil spring front on the 89 Bronco. There is already a 6 inch lift on the bronco as well. Does anyone know what I should do?
davids78bronco
fabricator extraordinaire
central Oregon
D50 won't swap in - it's too wide. You SHOULD be able to use the axleshafts from it, as well as the knuckles-out, and swap those parts to your stock TTB D44, to get the 8-bolt pattern that matches the rear
Gary wilder
