Traced all wiring form tranny to fuse block back to tail lights all is good is there a reverse light switch somewhere? could it be in the tranny or am i missing it? help!!!
It should be mounted on the shift linkage. When you have it in reverse, did you check for 12V at the light socket?
Also, if an additional post is necessary and on the same subject, keep your posts in the same thread by using the "ADDREPLY" button. Thanks /emoticons/[email protected] 2x" width="20" height="20" /> .
