79 rough start and idle
79shiverson
My 79 Bronco died approaching a toll and wouldn't start again without full throttle. I have checked all vaccum lines, drilled the catalytic converter, and cleaned the carb (no rebuild though). I was able to get it to idle only when I turned up the throttle on the carb but died when I put it in gear. I have tried to find other vaccum leaks by plugging the ends of lines to see if that is the problem. The engine serges and runs rough when it runs. The higher the RPM the smoother it runs though. Any ideas?
motor head
lehighton pa
hey i have a bronco that used to do the same thing i changed the plugs going to the catleatic converter and now it runs great
89Bronco58
Jersey
the intake could also be leaking or the gasket between the carb and the intake..check every gasket having to deal with sealing air out, if you dont find anything, id start checking the ignition next
Sandoval_broncosauria
