69 bronco windshield
Greg P
SE Massachusetts
I have a 69 bronco that I am tearing down to the frame. I need to remove the windshiled and frame so I can re-install it on another body. The windshield flips down but there are no screws or any sign of how it is attatched to the body. Are they spot welded? Thanks for any response. Greg P
wolfpack
Greg there are 20 or so spot weld across the lower hinge to the cowl.
29723[/snapback]
I've got a 67 and it's not tack welded...it's actually under your dash pad. If you lay your window down and then pull off your dash pad you should see about 6-8 bolts holding your window frame on....know this because I just pulled mine off last week...good luck
STLKIKN
Calgary Alberta
Wolfpack, the last year for the bolt on w/shield frame was 1968. After that they are all welded.
Sandoval_broncosauria
