4x4
ford_302
canby, OR
playing around in the mud today, 4x4 hi, as soon as you start spinning tires above 10 or 15 mph the front wheel starts to hop pretty bad, would this be worn u-jionts, too big of a tire for stock drive train? (33s) or is this normal? lol
RaginRedneck
I have a 92 w/ a 302 and I have a 6 inch suspension lift and 3 inch body lift w/ 35s and ive never gotten the front end to hop so id say that something is wrong but ive never heard of U joints being bad enough to make the front end hop but it could be i suppose
Miss Kitten
alberta canada
it could be something as simple as a loss of traction that was causing the front end to hop. in my dually when i'm in 2wd and in the snow the rear will start bouncing when i'm spinning. may be same effect but in the front for you
Definitely not normal. It could also be a mismatch of the front and rear differential gear ratios. If someone changed the rear ratio without changing the front the wheels will not turn at the same rate.
ford_302
ford_302
canby, OR
i guess it could be the gear ratios, but would you even feel the diffrence in mud? im talking snot slick absolutly no traction mud :rolleyes:
