Need some help.(please). Ive bought this 79 bronco w/ a 351m all stock. It had a dead spot when i would accelerate and it would not stay running at a intersection and would not idle in the morn. i replace the carb with a stock motorcraft 2bbl. The hesitation actually got worse, had the carb. reset and adjusted chock working ok ( i think) still had a bad hesitation when i get on the gas, to the point if i stay in to the hes. it will stall out, changed the dist,rotor,cap,plugs wires and fuel pump. The only thing iam not positive with is if the vaccume hoses are all proper and in place, not all the hose are hooked up i was told that the ones that are will be the only ones i need ?? cant find a diag. that shows all the vaccume lines from the 2nd dary can. I really hate that hesitation, Iam a capt. for our local fire dept. and when i have to
( go i have to go.. especially in the am LOVE my bronco need some veteren help.. Mike from the poconos
