mtneerfan
My bronco does not seem to shift into drive. It will run up to 25mph and the tach reads 3000rpm. It will not run any higher than this. Any ideas what the problem may be?
Maybe shift outa four wheel drive , trnsfer case locked, what ya got in the bronco?My bronco does not seem to shift into drive. It will run up to 25mph and the tach reads 3000rpm. It will not run any higher than this. Any ideas what the problem may be?
Transfer case is 2H, hubs are free. 302 w/ c6.Maybe shift outa four wheel drive , trnsfer case locked, what ya got in the bronco?BBB
Is it an automatic ? Last summer I had a very similar problem with my 88'. I was convinced the tranny was smoked but when I pulled it I found that the flywheel was broken. It had started with cracks between all of the flywheel bolts that eventually connected and sheared. This effectively turned my 1-piece flywheel into a 2-piece flywheel with the small inner part being bolted to the crank and the large outer part bolted to the torque converter. It would grab enough to spin the TC a little and I could get up to 10-15mph but I'd be taching out at 3K. It worked pretty well in reverse though. Don't know if that's what you're looking at but it might be worth considering. Unfortunately there's no way to visually inspect it without pulling the tranny. Here's my original post with photos:My bronco does not seem to shift into drive. It will run up to 25mph and the tach reads 3000rpm. It will not run any higher than this. Any ideas what the problem may be?
My thoughts exactly. Check you vaccum lines and the shift modulator.I don't know sht about a C6 but my C4 had a vacuum line loose and it kept it from shifting into 3rd. Might check that.
I got the problem fixed. The transfer case was not disengaging. It would not shift all the way into 2H.Thanks guys. I have spoken to numerous people and they also think it is the vacuum line or the modulator. I'll update you when I get it fixed. Thanks again
Thanks for the positve feedback Bully Bob.DOOOEH...!!!!
The second post had your answer all along..... BIGBLUEBRONCO
He said;
"Maybe shift outa four wheel drive, trnsfer case locked?, what ya got in the bronco?
BBB "
Glad your on the trail again.., thanks for the up-date, that's rare..!
