1991 bronco over heating
moore19842003
sice my cat is right by the trany if my cat is pluged can it make the trany hot in witch makes my truck over heat y it is in gear please help new thermastat water pump and raideater has been flushed im out of ideas
Most definitely if it is plugged and glowing cherry red. The cat has a heat shield but it won't do much good if the cat is seriously over heating. An over heating transmission will cause the engine to over heat. There are a lot of possibilities, but if you already know the CAT is bad, start there.
Also, if you don't already have one, consider installing a transmission cooler. They make a whole lot of difference in keeping he engine from overheating in hot weather.
You might also want to flush the system using a good engine flush solution.
