1990 front shock
TURK
clayton,de
help! I broke my driver side front shock mount today.i have a 1990 full size bronc
it as quad front shocks i broke the mount for the d/s front shock,the mount looks as if its a pressed in shouldered bolt may be welded.any ideas on repair
thanks
turk
Cl10racer
Pueblo West, Colorado
The best thing to do is to get one from a junk yard. When you get the old one off, drill some new holes in the mount and the frame and use grade 8 bolts to put the mount on.
Jasen
thanks
                  turk
25071[/snapback]
Those are rivits, you will have to grind them offand knock them out.
Turk, Welcome to Bronco Zone!!! I have the same concern on my 84 with the quad shock set-up. The front shock mount is very weak, just that stud protruding out from the axle mount. IF you can weld a box-bracket mount for the shock, si milar to that on the rear axle, that would be the best solution.
T
TURK
clayton,de
:)>- Thanks for the fast advise. the shoulder on the mount is still there and solid
Im thinking about grinding whats left of the broken threads off and welding a bolt to the shoulder then chopping the head of the bolt off so i can get the shock tight on the mount. what do you think ?
thanks again
turk
T
TURK
clayton,de
hello its me again got the front shock mount repaired the local parts store had shock mount repair kit.how it works is you grind off old mount drill a hole 1/2 inch
***** new mount in took about 1 hour to repair.just thought i would fill you all in
thanks again
turk :))
hello its me again got the front shock mount repaired the local parts store had shock mount repair kit.how it works is you grind off old mount drill a hole 1/2 inchscrew new mount in took about 1 hour to repair.just thought i would fill you all in
thanks again
turk :))
25121[/snapback]
Glad to see you got it fixed so fast,
eholt80
