1984 bronco ii
7111127
i just got a 1 wire alternator 130 amp i wanna install but old one is 3 wire how do i install the 1 wire in its place
anyone know?
If you are installing a 130 amp 3G alternator then the old voltage regulator on the fender is eliminated, it is included on the alternator. One factor to consider is the physical style of the alternator. Since you haven't included any information on your truck I can't help you much with installation.
You should use a heavier cable from the charge stud on the alternator plus you will need the wiring harness for the new alternator. The green with red stripe wire on the new harness hooks to the green with red stripe wire on the old connector.
fred tyler
