1984 bronco 2 4x4
susieq
I know this might be a stupid question to all
But , my Bronco is not getting gas to the Fuel Pump. My hubby is nervous cause we relpaced the filter and and they also took the hose off of the fuel pump and no gas but hubbby said there is vacum..
we dont have a tester for the fuel pump it self..
So should i just go head and replace it.
My truck does struggle to start and then shots off..
I hope i made since..
Sue
Are we talking fuel injected or carburetor here..?
"-----I hope i made since..-----"
Yes you did.... and it appears you're on the right track.
Unless there is some sort of restriction in the fuel lines, your fuel pump is likely the culprit.
Dangerous test but most do it.....remove fuel line at carb. & run a hose from there to a large container.
Disable the coil...or ground the center coil wire securely to the block.
Crank engine....should be a steady pulse of fuel entering the container.
"----So should i just go head and replace it (fuel pump)------"
This would be the safest bet...!
viperfangs2
Northwest Florida
it could be the fuel presuere regulator i went thourgh **** to fix the same problem on my B2 my fuel pump and the fuel presure regluater was bad i found out that my fuel pump went bad by haveing a buddy of mine listen for my fuel pump(it makes a hissing noise if its good) when i tryed to start it. be carefuel though im not sure if you have 2 fuel pumps i only had one you might have 2 one in tank and one out tank
fuel pump. so check those and check your fuel presure reguator
Good luck
S
susieq
Its only a regular carburator...
S
susieq
"----Its only a regular carburetor....."
Let us know what you find to be the problem....
WIll do.. BUt hubby needs to pull off alot of things in order to get to it..
So hopefully it will be done to day .. And I will let you know.
Thanks Sue
S
susieq
Well after 3 days of rain finally got back into trying to fix my Bronco...
We did replace the fuel filter and finally replaced the Fuel Pump and she still wont start,
now at wits ends,,,
Sue :( /emoticons/[email protected] 2x" width="20" height="20" />
S
susieq
still having no luck replaced a fuel filter and a new fuel pump still nothing enjine tries to turn over and then stops..
Sue
quote name='Bully Bob' date='Sep 11 2006, 06:19 AM' post='40776']
Big Country
San Antonio, TX
is there gas getting the the carb at all? If you smell gas it could be something else. let us know what else you have tried?
If there is no fuel getting to the pump then it can't pump any to the engine. Have you checked the entire fule line from the tank to the pump for crackec rubber connections? The steel portion may be bad and clogged or the pickup in the tak may be filled with crap.
fred tyler
