1971 Bronco What size Wheels Fit???????
firehawk
I need to know if 16x10 wheels will fit my bronco. I have not received it yet, so I cant measure.
The tires are 32x12 baja radials. Right now the tires on it are are 35's.
I am not sure if that is too wide of a wheel.
S_bolt19
Colorado
as long as the lug pattern is 5x5.5 it will be just fine. I am running 15x10 rims in 33x12.5 tires.
STLKIKN
Calgary Alberta
If your 16s are a 5 on 5.5" bolt pattern, then yes they will bolt on... problem with most 16" wheels is the backspacing on them....you may encounter some really nasty rubbing on the radius arms, especially with the wider tires.
Pericon
Mexico City
You need a 3" offset on your rims to avoid rubbing with 33s. Pleae post some picture i will post some of mines when I install my 16.5 with 36s.
Recko555
IA
i have 33x12.50 on 15x10 rims. 3 1/2" suspension lift. I have no rubbing on my radius arms.
GAbe
figjeti
