temperature guage reading overheating but not hot at all
tavar.cradle
tacoma wa
my 1986 ford bronco 2 has issues with my temperature gauge its reading like its overheating but it its lts not
Hi Tavar., welcome..!!
You can try replacing your sending unit on the engine. They can get dirty, leak &/or just plain fail.
       However, how are you determining that it is, in fact, not overheating..?
Well..., that's not a real good way.  Normal eng. temps are 180-190 deg. Trying to touch anything
under there (eng., radiator, etc) would cause one to yank their hand back reeeeeal quick..., let
alone an over heated engine.
Harbor Fright has a (+-$20) lazer temp reader that comes in handy all over the house & garage.
BTW., is the temp needle pegged or just reading high (i.e. somewhere above normal) ..?
A high reading often indicates a falty thermostat.
As Bob suggested;
Testing; "...Pull the R/Wh wire straight off the sender & ground it to the block, intake, or head. Then turn the key to RUN. If the needle pegs, replace the sender. If not, diagnose the circuit.
68bronc
