Whipsaw
- Joined
- Nov 26, 2016
- Messages
- 27
- Reaction score
- 21
Hi Everyone, its been a while since I've posted here. In the interim, with a new PCM installed, the Bronco has been running well. I do have a problem with high idle when it's warm out ( I think it's a vacuum leak, but I haven't looked that hard yet - if it's the plenum gasket, I'll get to that at some point. I have a replacement vacuum canister (coffee can), the old one is a little rusty, but I don't think its leaking. Turning off the engine and starting again fixes it for a time - if that might indicate what the problem could be). I did have it painted, stock emerald green, got it back from the body shop a few months ago - rust repaired, new front springs installed, new tailgate, new back glass. Looks great! I'll have to get a picture up soon.
The water pump seal just went (need to verify, coolant was running down the front of the engine, could be a cracked hose), if the pump is shot, will be replacing the timing set while I'm in there. After that is an Air Conditioning refit, and probably front wheel bearings.
