Jimmy Neutron
Land of Confusion
The frame finally rusted to oblivion on my 71 Bronco...
decided to part her out to help pay for the build of my 88 Bronco II.
These are all that is left:
The rear Ford 9 Inch
Measures 58" wide
5 on 5 1/2 bolt pattern for rims
31 Spline axle shafts
3.54 Gears
ARB Air Locker installed
-Compressor comes with too
Denver Leaf Spring pack included
The front Dana 44
Measures 58" wide
5 on 5 1/2 rim bolt pattern
30 Spline axle shafts
3.54 Gears
Limited Slip
Has been converted from drum to disc brakes
Drivers side drop
Coils and radius arms included
I also planned on including the rims and 33/12.5R15 tires, only about 20% tread left.
They do have mild surface rust
Axle housings are straight
Front and rear are set up for multiple shock locations
I believe the springs have a 3-4" lift
I know this is the wrong section for selling, which is why I am not selling them here.
I am looking for pricing... I usually ask my Dad because he has been 4-wheeling since before I was born, but his number and my number are quite a bit apart.
Can somebody give me an estimate?
THANKS!!
Measures 58" wide
3.54 Gears
The front Dana 44
Measures 58" wide
3.54 Gears
Limited Slip
Drivers side drop
THANKS!!
