roll bar
srm148
Chandler, Az.
does anyone know where I can get a roll bar for my 81 ford bronco. also, does anyone know if there is a kit available to put dual shocks up front and rear on the same bronco? any help is greatly appreciated!!!! thanks.
Welcome to the Zone > . Post some pictures and tell us a little about your truck.
You can get roll bars from Jeff's Bronco Graveyard http://www.broncograveyard.com. Not sure about the dual shock kit, but someone will chime in on that. :) /emoticons/[email protected] 2x" width="20" height="20" />
Good luck with your truck,
DV8R
Fremont, Nebraska
There is a dual shock kit avaliable for the 80-96 F 150 and Bronco for the front. I believe it is made by either Trailmaster or Rancho. I installed one on my uncles 82 F150. IMO it is a POS kit the upper bracket mounts to the spring perch with three bolts and the lower mount is a long bolt that goes through the existing shock and has a spacer inbetween sboth shocks. I will check with my uncle and see if he can remember who made it. I do know he ordered it from our local parts store.
srm148
srm148
Chandler, Az.
thanks ya'll. Broncograveyard.com does not have the roll bars at this time. they said check back in a month.
brian_n_texas
Melissa, TX
swracecars.com has a roll bar for Broncos. Justshootme84 (Randy) has one of these installed, but I haven't heard from him since hurricane Rita...
I am looking for a roll bar myself - most of the 4wd trail parks require one - but I want one that goes over the back seat too...I'm still looking around. I'll let you know if I find anything else.
BNT
eholt80
