Where do you add fluid? I don't see anywhere to add trans fluid!Hi Shu..., welcome...!!
That's a massive leak...!
Critical failure of some sort...broken line., line came loose, etc.
Putting more fluid in, will just leak out.
If you can get under there., you may be able to see the prob.
Once fixed., you may be able to add (proper Ford) fluid to the proper level & drive.
thats the idea. to spot the leak. so i see a yellow dipstick but i thought that was the oil. where is the oil dipstick?"Where do you add fluid? I don't see anywhere to add trans fluid!"
Again., unless you're adding fluid to watch for the leak., you'll just increase the size of the puddle.. :blush:
