ive never had a rear end go out on me before, but i have a bad feeling about this
first of all,
it has all brand new u-joints
the driveshaft (cv joint) was also rebuilt.
brand new trans mount i just put on 5 minutes ago
no broken motor mounts and rear end is tight on springs.
i took the rear driveshaft off and drove it in FWD
i checked ALL ujoints and they are in tip top shape
what happens is going from drive to reverse or vice versa it makes a big shifting noise under the truck and i see the transfer case handle buckle hard.
the problem is the rear end takes about almost a full rotation of the driveshaft to start turning the wheels at all.
also when i am slowing down, right when its about to come to a dead stop, i feel it shift also. then when i take off it shifts again
i know it sounds like the trans mount but it is not. it had a one-month old one on it and i just replaced it minutes ago and it didnt do anything either.
i feel like the rear end is interally really loose like its jumping around in there.
when the rear driveshaft was out i watched the front driveshaft and when putting into gear it only took 1/4 turn or less to engage up there. and it was MUCH MUCH smoother going into gear
what should i do? should i take it to a shop and have them test drive it and if so, rebuild it? would it be worth just fixing the rear to stock gears or get both rebuilt with 4.56 since i have 35's?
or is this not even my problem?
any ideas are aprreciated -im stumped-
thanks alot
first of all,
thanks alot
