Power Windows
hogtownhustler
how haed is it to change all the guts from electric windows to manual???
86 bronco
Shadow_D
Schenectady, NY
You will need to get the guts out of a manual door and get the door panel for the manual as well.
I guess my question for you is why would you want to convert? I will never go back to manual windows.
One less electrical part to fail :D /emoticons/[email protected] 2x" width="20" height="20" />
It is not hard to replace the electrical regulator with a mechanical one. Just a couple of bolts. You can get the entire setup including door panels from Jeff's Bronco Graveyard see pages 64 thru 69 in their 80 and up catalog.
H
hogtownhustler
the reason im goin back to manual is cause i wanna be in control of my windows not sum electrical part that can fail ......like both of mine ..........as it stands now i have to make sure i got tarps over my doors incase of rain plus i found to good doors with workin windows fer $50.00
H
hogtownhustler
motors bad.....track bent from someone pushin them up and down and now i broke the window in da drivers side...just my luck
shahrozali
