79highrider
Today i solved the issues of figuring out what to do with my worn 400m rebuild project and my dieing 351m in my truck. I bought a running 460 out of a 86 F250 mason dump truck. Now many many people have done this swap but I have a couple questions.
Firstly I want to use long tube headers, what headers fit the 460 in a 79 Bronco? Do i get 460 headers for a 79 f250/f350 4wd?
Another question, the mounting brackets, I know jbg has a set of engine mounts for the 460 into the bronco but what other companies do, what are the ones to get or should i take the mounts from the 86 and fab em to my frame?
Third question the 460 is currently bolted to a 4 spd manual dump truck trans and I want to bolt it to my C6, do i need to buy a flexplate or different flywheel to do that?
The radiators, which is best to use, the one in the dump truck or mine that came from a 79 with air conditioning (i think its a little bigger then one without a/c)
And the last thing i just want to make sure on, the 460 has electronic distributer advance and mine has vacuum, is one better then the other? and if i wanted to keep things simple the distributer in my 351m will fit on the 460 correct? so i could keep it vacuum advance.
