My buddy gave me his bronco he let die. Its been sitting for a few months so I replaced the battery and she slowly started. I turned her off to double check the fluid levels, and now she wont start. Turn the key, theirs a click, she has power (ie lights radio). Theres a click, the door locks engage then disengage, and then the mileage goes blank. Maybe the solenoid? some connection? What steps should I go in to avoid spending 2 hours replacing the starter???
[/q
yo, you have a 94, right? MY first reaction is a weak batty.
try the horn.. a weak horn = low batty due to that Slow Start; or bad batty/starter relay etc conns..
esp Grounds.
Check batty cable connections at batty, etc. If you have a multimeter, read voltage with lights on
Try this next..jump the starter relay; use a jumper wire where those Large RED & BLACK Insulated Alligator Clips are; watch fan for fingers, ties, ropes/chains around neck, etc.
If it won't turn over when jumped, you'll know that the starter is OK
if not, it's a relay issue (Bad part, bad ground, since it is grnd to the inner fender by the mounting ***** and its body) or ign sw or actuator rod or MLPS.
Old timers do this Using batty jumper CABLES- If it cranks while jumping across the 2 large terminals, the starter & large cables are good.
EDIT-highlighted most likely for you beginning with a weak battty, then cables and connections, etc.
Thanks Joe, but a lot of it is rote memory
