How to replace door handle?
PythonFarts
So I have a 1993 Bronco, and for the past month you would have to pull the drivers side handle real hard to open the door. I duno if its because it needs oil or because its freezing here but I just broke it off by pulling too hard.
I dont know what to unscrew on the door. I bought a 6 dollar handle from autozone. I have the picture of my door posted below, if someone can point me in the right direction as far as how to get this handle on please let me know. Thanks!
blkwlf
you'll have to remove a few screws that are visible on the door panel, then on the sides and bottom, gently pull the panel away from the door until the plastic push pins/clips are free from the metal (about 5 inches. then lift the panel straight up to remove it from the top window seal. after that it will be obvious how to replace handle. you will also have to remove the spring clip behind the window handle so you can take that off first before you remove the panel. once you have the new door handle on, just slide it through the hole and reverse the process.
eholt80
