fuel line on fuel injection rail
rogmit
I've got a 92 ford bronco with a 351windsor with a broken hose on the fuel rail that holds the 2 fuel rails together. Is this a specialty fuel injection hose because it justs pushes on the fitting with barbs and if it is isn't what size would it be?
Yo rog,
I believe it is reg. over counter fuel hose. Call ford dealer parts and ask.
It is shown, but not described in 96 bronco workshop manual.partial.
Same as most earlier years exc. for OBD II in 96, 4WABS (93-96); ABS (87-92); Air Bag (94-96); 3 ***** Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.);
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD
and a few other items that I still need to research
http://www.diesel-dave.com/vehic/manual/stj/stj34b07.htm
Not listed in ..http://www.fordparts.com/Commerce/CatalogResults.aspx?y=1992&m=Ford&mo=Bronco#Search
This may be a Winner!
Jeff
http://shop.broncograveyard.com/1980-1997-Ford-Bronco-and-F-Series-Truck-25-Ft-Of-5_16-In-Nylon-Fuel-Line/productinfo/30263H/
1980-1997 Ford Bronco and F-Series Truck 25 Ft. Of 5/16 In. Nylon Fuel Line
Item Number: 30263H
Unit Price: $29.00
Quantity 1
New
1986-96 Ford Bronco
1986-96 Ford F150, F250, F350
Detailed Description
Product Description
Easily and affordably restore the fuel line to safe, proper functioning with Dorman’s high quality Fuel Line. It’s available in multiple sizes, enabling you to replace only the damaged section-instead of the entire line.
•Save time, money and labor by replacing the failed part, not the assembly
•Constructed of high quality fuel-grade nylon or coated steel to for long-lasting durability against fluctuating under hood
temperatures
•Recommended for use with Dorman’s Fuel Line Repair Kit •Easily fits into the fuel fitting or fuel barb
1986, 1987, 1988, 1989, 1990,1991, 1992, 1993, 1994, 1995, 1996 Ford Bronco
1986, 1987, 1988, 1989, 1990,1991, 1992, 1993, 1994, 1995, 1996, 1997 Ford F150, F250, F350
fordblood
Fuel inection and carburetor fuel line is different.a ke sure to use fuel injection hose. It is a bit more expensive but regular fuel line won't stand up to the pressure and you will be looking at a potential fire.
Fryman22
