Engine Gremlin
96Br0nc0Guy
San Antonio,TX
96 E.B. with 351.
Throwing Codes 171/174 (Bank 1/2 Lean).
Took it to shop, they smoke tested and fixed vacuum leaks.
Have replaced the following:
PCV, EGR, MAF, temp sensor, air filter, all three O2 sensors.
The shop guys and I are stumped...
All thoughts or suggestions greatly appreciated.
Weak fuel pump?
There used to be a flow test to do on the pump and it was much more telling than just a pressure test.
It can provide enough pressure but if there is a restriction like a plugged filter it can still be starving for fuel.
Mjarrman
