Early Bronco Shaker kit
FordRamAir.com
Hi Guys, I've had many requests to make a functional shaker kit for the early Bronco. Well, I'm making plugs for some other projects and am willing to this one but I need help. I need some measurements off both a V-8 and L-6 truck. I need to know the distance from the air horn (top of carb where air cleaner sits) to the hood and where the scoop should be in relation to the carb. Do you want it directly over the carb ? 6", 12" ahead of the carb ? For the L-6 trucks I need to know the above as well as how far off to the side is the carb. This is in relation to the centerline of the truck. I can use some large format pics of the engine compartment and top & bottom of the hood. Which scoop is prefered, Mustang or Torino. With your help I can make this happen.
Thanks
Leon
eholt80
