Yo Richard,
Yes, missed you and your Bronco!
BTW, you just achieved the Post Count Century Mark!!!!
No prize though, but some answers.
Sorry, no way I can post pictures nor highlight, etc., I lost the capability here awhile ago, but I have the urls shown here for most & asterisks (***) for most significant words or phrases.
Yes get a yard PSOM.
http://www.hollanderparts.com/
A yard that uses Hollander Interchange can search other yards and have it shipped
Can select certain parts
Has Vehicle Pics! They show about 3 - 5 pics for some vehicles
Here is one!!!; $59.97; Ship for $10.00 Excellent Condition (Grade A); *** Mileage 196,000 ***;
B & R Auto Wrecking PORT Corvallis, OR
Buy or View Details
http://images.hollandersolutions.com/ADA/COL/RP4/EJR/O.jpg
or
http://www.copartfinder.com/finder/searchMake.do
Has Vehicle Pics! They show about 4 - 5 pics per vehicle incl. interior/dash, back seat, front & rear and engine bay.
Can NOT Select certain parts
http://www.car-parts.com/
Has Some Vehicle Pics! They show about 4 - 8 pics per vehicle incl. interior/dash, back seat, front & rear and engine bay
http://www.picknpull.com
This is a Company name w/yard locations in various states
http://row52.com/Search
Has Vehicle Pics AND Want a Part? It's Easy...
1. You create a Parts Wanted Listing.
2. Parts Pullers respond with offers.
3. You pick the best one.
A Parts Puller gets the parts you need.
for obsolete parts by Ford long version pn:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
https://consumerlink.oeconnection.com/91554453363118850 (suggested by JScatt!)
Your odometer looks strange because of LCD Delamination, as happens to some rear view Electrochromatic mirrors. The *** *** instrument cluster especially PSOM requires special handling to avoid damaging internal components. The cluster *** MUST be kept FACE UP or in the in-vehicle position. *** Leaving the cluster face down may result in a loss of dampening fluid used in the gauges. The lost fluid could stain the cluster face or result in excessive pointer waver..."; in a 96 from 1996 F-150, F-250, F-350, Bronco, F-Super Duty Motorhome Chassis Workshop Manual
Source: by Ford
When I thought my PSOM was bad I shipped it to DNA SPEEDOMETER, but an nasty lady at the UPS store tossed my Well-Wrapped and labeled, "THIS SIDE UP, FRAGILE" shipping box into the a hamper despite my request to handle it as described. I contacted the stores owner, he came over in 10 minutes, saw the box laying at bottom of hamper and relieved the woman permanently. He shipped it for free. *** DNA speedometer folks said the odometer section was stained upon receipt, the same as hownyour odometer apears. However, it has not worsened to date. ***
anyone needing PROGRAMMABLE SPEEDOMETER/ODOMETER (PSOM) or other repairs check out DNA Speedometers; Tampa, FL 33614
http://dnaspeedometers.com
Their PSOM repair prices are about $200.00 lower than Ford (using the Electronic Odometer Exchange Center) and a few other repair places.
They do:
Odometer reset w/ Validation; Digital/Analog Repairs
Odometer Mileage Setting Mechanical Speedometers
***!Dark or Partial LCDs Electronic Speedometers ***
VDO Pixel Repair - BMW, Benz
Rebuild Speedometers;
Analog & Digital Odometers
Speedometer Replacement
Great Customer Service!
Master Cylinder Proportioning Valve was renamed Master Cylinder Fluid Control Valve in later years; around 1992 I think.
The brake master cylinder fluid control valve (2C161) regulates the hydraulic pressure in the rear brake system. It is located on the brake master cylinder (2140) and is screwed into the rearmost outlet port. When the brake pedal (2455) is applied, the full brake fluid pressure passes through the brake master cylinder fluid control valve to the rear brake system until the valve's split point is reached. Above its split point, the brake master cylinder fluid control valve begins to reduce the hydraulic pressure to the rear brakes, creating a balanced braking condition between the front and rear wheels (1007) to minimize rear wheel lockup during hard braking.
In case of the front brake system malfunction, the brake master cylinder fluid control valve has a bypass feature which allows full hydraulic pressure to the rear brake system.
http://www.diesel-dave.com/vehic/manual/stj/images/h5609f.gif
http://www.thedieselstop.com/faq/9497faq/maint/96fman/images/h9908a.gif
Ford price is 2C161
Master Cylinder Control Valve $69.75
http://www.fordparts.com/Commerce/CatalogResults.aspx?y=1993&m=Ford&mo=Bronco#Search
You can place a 92 to 96 differential in as long as it has the VSS SENSOR & Tone Ring (inside the diff) for PSOM, PCM, E4OD, & Cruise Control if equipped; with any ratio if you do Not use 4x4. Or ratio is the Same for when you use 4x4.
"...Ford typically builds 4WD trucks with a slightly faster/numerically lower front gear ratio than the rear so that off-road steering is enhanced. So a truck built with 3.55 rear gears will have 3.54 front; 3.08 rear - 3.07 front; 4.11 rear - 4.10 front, etc..." Following was in my MS WORD Notes and the source, Randy's Ring & Pinion has removed it from their current web site; The gear ratio in the front of a four wheel drive has to be different from the front so the front wheels will pull more. There have been many different ratio combinations used in four-wheel drive vehicles, but not so that the front will pull more. Gear manufactures use different ratios for many different reasons. Some of those reasons are: strength, gear life, noise (or lack of it), geometric constraints, or simply because of the tooling they have available. I have seen Ford use a 3.50 ratio in the rear with a 3.54 in the front, or a 4.11 in the rear with a 4.09 in the front. As long as the front and rear ratios are within 1%, the vehicle works just fine on the road, and can even be as different as 2% for off-road use with no side effects. point difference in ratio is equal to 1%. To find the percentage difference in ratios it is necessary to divide, not subtract. In order to find the difference, divide one ratio by the other and look at the numbers to the right of the decimal point to see how far they vary from 1.00. For example: 3.54 ÷ 3.50 = 1.01, or 1%, not 4% different. And likewise 4.11 ÷ 4.09 = 1.005, or only a 1/2% difference. These differences are about the same as a 1/3" variation in front to rear tire height, which probably happens more often than we realize. A difference in the ratio will damage the transfer case. Any extreme difference in front and rear ratios or front and rear tire height will put undue force on the drive train. However, any difference will put strain on all parts of the drivetrain. The forces generated from the difference have to travel through the axle assemblies and the driveshafts to get to the transfer case. These excessive forces can just as easily break a front u-joint or rear spider gear as well as parts in the transfer case. by me @
http://broncozone.com/topic/21803-new-member/?gopid=113959&do=findComment&comment=113959
To the best of my knowledge the front springs are the same for 2 or 1 shock per side. As built, there were at least 4 spring "sizes"; type c, g, v or u installed.
Suspension Spring Codes in a 96 by Ford;
http://www.diesel-dave.com/vehic/manual/stj/stj01019.htm
See your Door Jamb Label;
For instance, see this pic in a 93 5.8 & E4OD by broncofocused (Super Bronco) at
my 96 xl w/E4)D and 5.0 has Code D; Ford pn F4TA-5560-DB
Alvin in AZ wrote; (click and see 90 coil pics there by 1990bronc, as well as my info, etc.)
Front spring codes Bronco:
B = E0TA-5310-BC = ~.675"wire (was on my '91 Edwina Bauer)
C = E0TA-5310-CC = ?"
G = E0TA-5310-GC = ?"
U = E0TA-5310-UC = ?"
V = E0TA-5310-VB = ?"
