A lift for 33inch?
jagger
I am sure this has been asked a million times before but I am a newbie and I need to know do I need a lift for 33" on an 86 full size?
If so any good cheap or inexpesive suggestion, nothing to extravgant it is just for fun
thank you very vuch
Jagger
No you do not need a lift for 33's on an 86 Bronco, they will fit inside the wheelwells (assuming the suspension is in good shape). WHether or not you will have fender contact will depend on the actual tire height, wheel size, and how hard you wheel the Bronco. Try a forum search, I have 33's on my stock 86. I would recommend a 4" lift if you plan to do some trails or flex the suspension to it's limits, as you will have contact without a lift.
rubberdust
Henderson NV
33X12.50R15s should fit without a problem on an 86. With a great amount of articulation & the wrong wheel offset you might be able to make them rub. A 33X10.50R15 will clear even on the trail all twisted up.
J
jagger
Thanks for the input guys I should have some 33" in the near future
Jagger
mudder95
Reading Pennsylvania
I am sure this has been asked a million times before but I am a newbie and I need to know do I need a lift for 33" on an 86 full size? If so any good cheap or inexpesive suggestion, nothing to extravgant it is just for fun
thank you very vuch
Jagger
23459[/snapback]
here this should help big broncos tire guide
eholt80
