A/C delete
MUDD
MICHIGAN
Will FULL elimination of ALL A/C re-lated parts affect/cause issues such as,heat or defrost modes?
Shaggy
Administrator
Arizona
How are you planning to do the A/C delete? Just yanking it all out?
M
MUDD
MICHIGAN
That makes it sound so B.R.U.T.A.L.-I will approach it a lot more surgically than "yanking it out" Do you know whether I can expect issues w/heat and/or de-frost function? Thanks
Yo MUDD,
In the DEFROST position, outside air is discharged through the windshield defroster hose nozzles with a small amount going to the heater outlet floor ducts. A/C clutch is engaged in ambient temperatures above approximately 50°F. Air Conditioning acts as a dehumidifier causing windshield and some of side windows to be cleared.
