89' 5.0 Fuel Accumulator Reservoir
Gary202
Texas
Greetings all,
Been a member for a while but not active. My issue is the fuel accumulator reservoir is leaking. I have not been able to find one. I was told they are not made any more. What I can find is one for a double tank F150.
Anyone have any idea where I could locate one? Thanks in advance.
Gary202
Greetings all,
Gary202
Yeah, that accumulator being NLA from Ford is a common headache on these, so you're not the only one hunting. The double-tank F150 piece is worth a shot since the 5.0 return systems were basically the same era, just eyeball the fittings and mounting bracket before you commit so you don't end up fighting it. Have you had any luck at a local pick-n-pull? An 87 to 89 F150 or Bronco donor is usually the quickest way to grab one that drops right in.
Appreciate the response. I think your right and about a donor, have a great week.
Civilfiredog
Back
