Not starting, long story short have re[placed a lot of parts because the rig sat for a number of years. new coil, spark plugs, spark plug wires, went to replace dist. cap but one of the screws holding the cap snapped off, tried to drill out no luck. So replaced the dist. Manually turned engine over to get cylinder 1 to top dead center, continued to move engine over to align timing mark to 0 on the engine marker bracket. Had marked old dist. for cylinder 1, matched up new dist. for same. Set rotor to point to cylinder 1 mark and installed new dist. went in and looks about like old was before. Replaced MAP sensor, fuel relay because pump was not coming on. Replaced another relay that I do not remember the name of, I think EEC the one that sends voltage to fuel relay because I was getting half the voltage required now voltage is correct. Replaced fuel filter in front of fuel pump. Still not starting, so put a fuel pressure gauge on the shrader valve, KOEO 0 pressure. KO engine turning over about 9 pounds of pressure. Replaced fuel pump on side of chassis. Same exact readings on the fuel pressure gauge. And no fuel out the relief on the gauge either time just air. Any help would be appreciated, I am at a loss. Thanks.
