624 code on obd1
B1gCountry1107
Chesnee, SC
im trying to get my 1995 bronco up and running. I hooked the obd1 up and got code 624 and i was wondering if anyone had any information about this code or what part it might be.
OBD code for newer eec(s)
624: Solenoid/circuit failure -Electronic Pressure Control (EPC) current is high – Transmissions 624 could be an ELECTRICAL fault, not a mechanical or hydraulic problem. You probably have a wiring problem (bad connection, corrosion, faulty solenoid, or PCM)
Most the time Transmission codes are bad solenoid packs more then bad transmissions. I had my Pack replaced recently for ~$600 at the local transmission shop. If I were in your shoes I would take the time to inspect all the wiring before stopping by the trans shop.
mothony
GA
Could be the solenoid packs or a driver circuit failure.
